Are you looking for Sea Gull Lighting 98611SW-15 24V Led Strip Lighting 2 in. Section in White Face? We found best price for you. Go to link below to buy the Sea Gull Lighting 98611SW-15 24V Led Strip Lighting 2 in. Section in White Face for the lowest price.
Sea Gull Lighting 98611SW-15 24V Led Strip Lighting 2 in. Section in White Face Review
Just received my Sea Gull Lighting 98611SW-15 24V Led Strip Lighting 2 in. Section in White Face. I'm amazed with this lighting accessories!
Sea Gull Lighting 98611SW-15 24V Led Strip Lighting 2 in. Section in White Face Description
2 section of 24V Ambiance Lx Lite Flexible LED Tape lighting with white PCB face. Connects to other sections of 24V LED Tape lighting. Sea Gulls Ambiance Lx Lite Flexible LED Tape lighting contains 12 warm white LEDs per foot on flexible copper strip encased in optically clear protective coating. Lx Lite Tape lighting works and dims with all 24VAC magnetic transformers. For increased light output LED Tape lighting can also be powered by 24 VDC LED power supply unit. Installs easily on surfaces with included clips or self adhering industrial 3M adhesive (provided on back of strip) . Maximum run length for 24V is 40 feet. Finish: White. Dimensions: Length: 2 x Width: 3/8 x Height: 1/8. Listing: CETL Listed for Damp Locations. Available in a variety of lengths including 1ft 5ft 16ft and 2 sections and with wide variety of connectors. Field cuttable at everyes to end a run. provides the look and feel of halogen and xenon with energy savings of up to 90%. 12 LEDs per foot produces 150 lumens per foot and consumes 3 watts 12VAC per foot. Power using VDC for increased light output of 180 lumens per foot. 2 section of LED tape consumes .4 watts. Lumen package is comparable to traditional undercabinet lighting 10W xenon to 20W halogen 4 to 6 on center. Long 40000 hour life last 20Xs longer than halogen for maintenance free operation. Color accurate illumination CRI 85 3000K CCT- improves visibility and perceived brightness. 24VAC or 24VDC operation dimmable with a wide range of incandescent and ELV dimmers can be connected to 24VAC Ambiance LX systems. CETL listed damp location. Evironmentally friendly contains no mercury and emits no UV or IR. The advanced LED technology in Sea Gull Lighting products is carefully designed and selected to consist of t
Related posts
- Sea Gull Lighting 98611SW-12 24V Led Tape Lighting 2 in. Section 3000K
- Sea Gull Lighting 98605SW-12 12V Led Tape Lighting 2 in. Section 3000K
- Sea Gull Lighting 1135AT-15 Recessed Lighting Trim in White with Smooth White glass
- Progress Lighting P7503-30WB Hide-a-Lite I 10 Light Lighting Strip in White
- Sea Gull Lighting 1156AT-14 Recessed Lighting Trim in White with Baffle glass
- Sea Gull Lighting 11134AT-15 Recessed Lighting Trim in White with Clear glass
- Sea Gull Lighting 11094AT-14 Recessed Lighting Trim in White with Baffle glass
- Sea Gull Lighting 1162AT-172 Recessed Lighting Trim in Antique Bronze with White glass
- Sea Gull Lighting 11091AT-15 Recessed Lighting Trim in White
- Sea Gull Lighting 9435-15 Linear Lighting Track in White
- CSL Lighting XE-94-WT Abeo 15 Light Lighting Strip in White
- Sea Gull Lighting 1160AT-14 Cone Reflector In White With White Finished Trim
- Sea Gull Lighting 7639-15 2 Light Flush Mount in White with Smooth White glass
- Sea Gull Lighting 90619-68 Address Light Accessory - White Blank Tile- White Plastic
- Sea Gull Lighting 98175-15 Cable Transformer in White
- Sea Gull Lighting 94035-15 Track Accessory in White
