Back to blog
PowerBridge CSIW-WH Cable Solution Wall Plate for Low-Voltage Bulk-Wire Cabling - Each White
Are you looking for PowerBridge CSIW-WH Cable Solution Wall Plate for Low-Voltage Bulk-Wire Cabling - Each White? We found best price for you. Go to link below to buy the PowerBridge CSIW-WH Cable Solution Wall Plate for Low-Voltage Bulk-Wire Cabling - Each White for the lowest price.
PowerBridge CSIW-WH Cable Solution Wall Plate for Low-Voltage Bulk-Wire Cabling - Each White Review
I own some wall plates & inserts, but PowerBridge CSIW-WH Cable Solution Wall Plate for Low-Voltage Bulk-Wire Cabling - Each White is my most favourite.
PowerBridge CSIW-WH Cable Solution Wall Plate for Low-Voltage Bulk-Wire Cabling - Each White Description
FeaturesAll - in - one design pass - through wall plateFor use with low - voltage wiring onlyDrywall wings for secure placementSimplified do - it - yourself cable managementSwitch out removable and replaceable inserts (additional inserts sold separately) for custom cable solutionsColor - White
