Are you looking for Cables To Go 40059 6ft PRO-AUDIO CABLE XLR MALE to XLR FEMALE? We found best price for you. Go to link below to buy the Cables To Go 40059 6ft PRO-AUDIO CABLE XLR MALE to XLR FEMALE for the lowest price.
Cables To Go 40059 6ft PRO-AUDIO CABLE XLR MALE to XLR FEMALE Review
Look at the cost It costs just 19.19. I have been looking for this purchase everywhere. I found it only at this UnbeatableSale.com.
Cables To Go 40059 6ft PRO-AUDIO CABLE XLR MALE to XLR FEMALE Description
Impact Acoustics Pro-Audio cables are made from twisted pair audio cable under an aluminum foil for maximum shielding from noise. High flexibility 7mm PVC jacket reduces the risk of cables kinking and damaging the conductors. Bright nickel plating on solid brass connectors resists wear from reconfiguring and moving equipment from one venue to another. Chuck strain relief inside the XLR connector reduces the effects of age on the solder joints and contacts. Features: 22AWG Twisted Pair construction. Foil shield and 60% copper braid. Nickel plated brass connectors. Connects balanced line outputs to balanced line inputs.
Related posts
- Cables To Go 40052 3ft PRO-AUDIO CABLE XLR FEMALE to RCA MALE
- Cables To Go 40056 50ft PRO-AUDIO CABLE XLR FEMALE to RCA MALE
- Cables To Go 29771 SONICWAVE 3.5mm MALE TO 2 RCA TYPE FEMALE AUDIO Y-CABLE
- C2G - Cables To Go - 52119 6 inch USB 2.0 A Male to A Female Extension Cable
- Cables To Go 26686 3m USB A Male to A Female Extension Cable - White
- Cables To Go 28066 1Ft Usb 2.0 A Female To B Male Panel Mount Cable
- Cables To Go 28074 3ft Panel-Mount USB 2.0 B Female to B Male Cable
- Middle Atlantic UCP Series Female/Male XLR Cable Punchout; 1 Female/ 1 Male
- Middle Atlantic UCP Series Female/Male XLR Cable Punchout; 2 Female/ 2 Male
- Ultra U12-41888 A-Female USB 2.0 To B-Male Ps By 2 Cable Adapter - USB 2.0 Ps By 2 Female To Male
- Ultra U12-41900 A-Male Db9 To B-Female Ps By 2 Cable Adapter - Db9 Ps By 2 Male To Female
- Cables To Go 40427 6Ft 3.5Mm Stereo Male To 3.5Mm Stereo Female Y-Cable
- Insten (r) 1/4" Audio to 1/8" Audio Male/Female Gold Plated Adapter
- Hosa Technology GXR-134 XLR Female Audio To RCA Male Audio Adapter
- Ultra U12-41904 A-Male Dvi-I To B-Female Vga-Svga Cable Adapter - Dvi-I Vga-Svga Male To Female
- Insten (r) 3' Digital Optical Audio TosLink Male/Male Cable; Black
